vp44 gear difference 98.5 to 01
Ok because the truck is a 01 that have been swap with a 98.5 and the truck is in limp mode because off the diffenrence cam 01 and cam and crank sensor 98.5 . So i want to buy a 01 block with no turbo manifold and vp44 so i want to put all my stoff that run the 98.5 on the 01 that deserve to be in the truck
Well, it could be a wash that way. I am just the kind that would take the 98.5 engine & rebuild it & then swap everything over, while using the 01 engine as a temp, but that's just me. My wife tells me I am a hoarder.
You may find a housing & cam from a blown engine at a salvage yard on www.car-part.com It is also a good site for cross referencing what parts fit, as they use the Hollander Interchange system to only give direct crossed parts. You may also check diesel shops for a used housing that is left over from a P pump swap.
Ed
Edited by Yankneck696
