No heater controls, vacuum pump working
My truck has another problem this week.  HVAC is stuck on defrost, the vacuum pump produces vacuum, and all the hoses are connected.  How much vacuum should I be seeing at the vacuum distribution plugs near the heater output?
there is some oil leakage through the vacuum pump, so is this causing poor vacuum?
Are you positive the small vacuum lines in the engine compartment along the firewall are all connected? Small hard plastic vac line comes up from vac pump to firewall on driverside of engine and tees into a manifold of sorts, one line goes down back side of engine and along top of trans to supply vac for CAD system on 4wheel drive and the other lines go through the firewall and are what supplies the selector vents with vacuum
