He351ve stand alone Arduino controller code for 2nd Gen Cummins
i was looking at one of the libraries and that looks like they have libraries in them i may not have.  i only seen the can bus library at the beginning
edit: i looked over the libraries and dont see what im missing any suggestion to what i should be looking for?
Edited by flopper85
not sure why my lcd isn't working with this code or my mega and i was also wondering i see it alot but i see people put positive in there lcd address like you did but i haven't had that work maybe you can explain?
this has worked for my other boards but not with this set up.
got it i had to add to the code
  lcd.init();
    lcd.backlight();
 for my lcd
Edited by flopper85
ARGHH, So I sent out the actuator to AVI electronics in Illinois, who updates and rebuilds vgt and other stuff. I got it back today. Hooked everything up and it does the same as before.
I hook up the pos n gnd and the actuator spools up for a second.
I hook up the Can to the arduino (arduino +Canbus + lcd shield to calibrate)  and RX led illuminates.
On the serial plotter it is sending the commands, but theirs no response.
Everything is straight connected. Any thoughts? I'm going to go back an reread everything...
Alright, new arduino mega, and Canbus shield. Tried different libraries.
Still does the same thing. Spools up for a second then stops. Tt doesn't jog
RX is still solid lit.
Is their somewhere in the coding that the Can has to be defined or something?
I find it hard to believe that this actuator after being sent out, new board and updated software.
When I connect the power and ground to the actuator, whether its connected to the arduino or not, the motor starts spinning. accelerating, and then decelerates.
It doesn't jog like its supposed to. Jog, like the motor twitches for a moment.
RX receive led on the Canbus shield is solid lit up.
Next look at your board setup.  Some canbus shields use pin 11 some us pin 10 or 9.
mcp_can1 ();  is what defines that pin.  Verify using the documents on your can shield what pin it uses.  then ensure you are not getting other transmissions on that shield.
IE make sure your LCD isn't using the same pin in the code as the canbus shield.    Or if your shield uses pin 9 then you will have to adjuste my code to use another pin of EBSwitch.
I am guessing you have a conflict similar to that.
Edited by Me78569
On ‎2‎/‎19‎/‎2015 at 2:47 PM, Me78569 said:
Issue is the boost map for vein position at various psi's doesn't account for the 14 psi that we always have
Only the people near sea level elevation have the rounded figure of 14 psi.  Where you are in Colorado Springs, the atmospheric pressure is about 11.8 psi.
Just being technical.
- John
- John
technically correct, I dont remember the context.
