I have a 2001 Ram 2500, 4WD, 6 speed.  The cruise control indicator is always displayed on the dash, even before the truck is started.  None of the cruise control buttons do anything.  So, the cruise isn't working.  I took the truck to auto zone and they reported that the truck wasn't throwing any codes.  I attempted to contact dripley because he seemed to have this same problem, but his account no longer accepts messages.  My best guess is the clock spring.  Thanks in advance for any and all help.
Dripley the last I knew was having personal issues and would come back when he was ready.
My best guess would be to ohm out the wiring for the cruise control.
Danger Icon DANGER!
WARNING! Be careful about suppling voltage to the air bag module you might trip it off.
So I suggest you unhook the batteries and wait 15 minutes and then unplug the air bag module. Then you can test against the cruise control buttons. Each one should have a different resistance.
