The Stealth AirDog on a 3rd Gen
(0 reviews)
Here you go, gang, I've gone and done it now. I found the next great hiding place on a 3rd Gen Truck and gave the AirDog a protected spot. I mocked up the bracket in the bed and then mounted the pump bracket upside down against the inner bed wall. This makes it a bit tricky to get the 4 Allen bolts in and tight. Then I managed to get the suction line hooked up to the modified sender straw. Then I removed and cut the filler neck hose and inserted the return tee into the filler neck hose. Clamped the tee in place in the filler neck hose. Now hooked up the return line for the AirDog. I'm going to have to redo my electrical, since I need a bit more wire to reach the pump, but I'll get it.
I crawled under Thor and using a 1/2 breaker bar and loosen the fan belt tension. I was able to hop up on the bumper and get the new idler pulley installed and tighten up. Now I'll admit the fan belt was a bit higher with the new pulley. Got it all back together.
Then I was looking at my leaking radiator. The driver side radiator header tank is cracked in the front face. I've got to look into replacing the radiator in Thor since the plastic tank is cracked. Maerk and I are looking into the idea of plastic welding the crack shut for a band-aid fix.
View the entire Thor - 2006 Dodge Ram 3500 album
1 Comment
Recommended Comments
LiveOak
Have you check Rock Auto? Recently, they had a lot of clearance parts on sale at they did for my 2nd Gen truck.
