Hi guys, been a while. I'm having a problem with my truck getting up to temp. Unless I'm towing. But on normal driving edge on 5x5 it stays about 140 degrees.
Any thoughts?
  • Replies 7
  • Views 1.4k
Ok thanks. Saw the thread on the 190 vs 200 thermostat. Prolly just use 190 since its summer right?
I think it depends. If you do a lot of pulling you should go with the 190. If it's just a DD that doesn't get worked hard very often go with the 200
Well it's funny. When I first got this truck all my friends asked what I tow. At that point it was just groceries and beverages.
Since then I got a huge boat and a dump trailer and a car hauler. I even towed a backhoe home 300 miles with the 02 black dodge auto trNny. 40,000 pounds total weight on 5.9!!
Think I'll do the 190.
200 in the winter when I don't tow
Thanks you guys!! I'll get thermostat on Monday from dodge unless you think run of the mill from big daddy auto chain is sufficient ?
; ipsSettings['maxImageDimensions'] = { width: 1600, height: 1600 }; const ipsJsFileMap = {"communitymap":{"front_markers":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_markers.js","front_showmap":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_showmap.js"}};
