Drivers Side Fender and well liner
Cant find the thread I thought existed .... if someone has the link. Drivers side.
Basically looking to see what needs to be done.
Remove all bolts at front support brace near radiator
Remove the battery,  tray and bolts x 4
Remove the ABS bolts x 3
Remove the rear bolts for fender
what else ?
:thumb1:
  • Replies 10
  • Views 3.3k
You pretty much got everything. I just unbolted the abs/fuse box and tied it up with a bungee. Snake the headlight wiring out of the way as much as you can, mine got damages when the fender dropped unexpectedly. Big bracket by the hood hinges has to come off. There is sneaky bolt that took me a little while to find. It's underneath in the wheel well about level with the top of the tire. There are a lot more bolts in the fender than I was expecting so take your time.
Beautiful - thx Buzzin  :thumb1:
How long to take off - 2 hours ?
About the same back on ?
Ya I probably spent 1-2 hours taking the first one off. Could probably do it in half hour now that I know the process. Getting it set back in place didn't take long but the real struggle was trying to get the doors fenders and hood to line up since I had them all off and they were from a different truck. If your just doing one fender it shouldn't be nearly as bad.
Thanks.
I have a rust spot about the size of 3 fingers punch through near wheel well.
$200 to have it patched .......and with fibreglass
But have a mate that has one I can get for free ..... just need to paint and remove/install.
Wow... and I live in the rust belt too. But I've got nothing that bad.
They must use some sort of anti-dodge salt on the roads up here. I see a lot of second gens in my area that look like this. I don't think the previous owner ever washed it which didn't help.
I also live in the rust belt they go nuts with that liquid stuff on the road I use an old lawn sprinkler that spins with adjustable nozzles stick the garden hose under the truck in the front get it to the back attack the sprinkler turn on water pull the hose very slowly forward and it washes the salt off the underside
They love the liquid here... Weekely washes have kept the truck 100% rust free.
