How often must I donate?
Recently I made an in-between donation. After a few weeks I got an invoice which I disregarded because I had just donated. I see I am a donor now but I have also been pink listed. Do I have to donate every six months even if I just did a month ago or how does it work?
  • Replies 7
  • Views 1.9k
Let me back track this you might be falling out of the old system and mixed up in the new donation system basically criss-crossed.
(Digging...)
Well I did find the database got hung up but clean up the mess. More or less because your leaving the old donation system and entering the new system why the hang up.
Thanks Mike! One other question. When I try to upload an avatar it says the file is too large, even when I try to use the same picture I had. How do I change that?
Daily donations are appreciated. set up for a donation each time you visit. $100 or so would work.
Just messin with you. Hope Michael got you covered.
What is preferred for donations, split up over the year or just one donation annually?
There are some perks for you if you give certain amounts at one shot. Such as advertising ability for personal business @ $100 if I recall.
