Motor quits, cranks over but won't start.
Motor quit while idling, cranks over but won't start, no power to fuel transfer pump and injector pump, code displayed [ no bus] on onboard system check. Help.
  • Replies 6
  • Views 2k
If you fill out your signature (year of truck, options, add ons, mods, etc) it will be very helpful to those who are "in the know"
Dec 01, 24 valve, no add on's or mods, low mileage truck.
Edited by Tom3
I would start with the relay in the big fuse panel under the hood. Find the one for the fuel system and swap it out with another one see if that's it.
Yeah that was the first things I did,tried relays and fuses but no joy
Ok, got it working now, disconnected all the harness plugs and plug ins found nothing obvious but everything working now, thanx
