Help! No water temp, oil pressure, or tach. ECM failure?
- Replies 9
- Views 10.2k
GD1210 4 posts
Mopar1973Man 2 posts
guesswho512 1 post
dobienut 1 post
Hey everyone, I'm new to this site. I came across it after trying to figure out some issues I've been having with my '01 24v and am hoping someone could provide me with some insight. Now here's the problem:Today I was driving my '01 24v (mods in signature) and everything was perfectly normal. I then shut it off and about two hours later started it up. When I started it up again, the water temperature gauge, oil pressure gauge, and tach were all not working. The truck was running and idling perfectly fine and the check engine light did not come on. I did notice that when I turned the key to the start position, the oil pressure and water temperature gauge both twitched, so I know they definitely have power. But just incase, I checked all of the fuses and all were good. I then checked for codes and got a P1694 code, which came up as "Fault In Companion Module." So now I'm beginning to think it's the ECM. I'm really hoping I'm overlooking something that may possibly be faulting the computer. Any ideas or input? Thanks in advance.
