abs
My abs and brake light are one I am thinking a have a front sensor out. I wanted to make sure there wasn't a wire broken and I can't for the life of me even find them and I just missing them or does the wheel have to come off
  • Replies 29
  • Views 4.1k
Change the speed sensor didn't help  i got a new abs box from the junk yard  same year as mine is there anything that is different or should they be the same
So it won't just plug in and fix my abs light
When I put the rear sensor I went for a short drive and the light never turned off
It might do that but it might have the speedometer way off or it might be close. You can flash the ABS module with a frequency offset for correction of tire sizes. So lots of oversize tire uses typically do this to get the speedometer corrected. Not knowing what was done to the module or what size tires where on the vehicle its a guessing game.
When I get some time this weekend I might  try it to see what happens just getting tired of the dang light on
I couldn't sleep this morning so I went ahead and put the other box in. To my surprise  the lights turned off for a mile or so then turned back on. Strange thing is that my brakes are a little softer witch is a good thing they where so dam hard
