Fabbing up a new lower and upper dash?
- Replies 7
- Views 2.3k
The_Hammer 3 posts
dripley 2 posts
CSM 1 post
toughtoy4x4 1 post
I just pulled the entire lower dash out, drilled out all the rivets holding the plastic to the metal sub-frame, removed the plastic and put down a layer of fiberglass on the back side for reinforcement, then riveted it back to the metal subframe. While doing this I started thinking about fabbing up a completely new upper and lower dash to replace the plastic garbage Dodge so graciously blessed us with. Has anyone done something like this? I'm not talking about a bare bones dash you see in a race truck but rather something that looks factory. If I decide to do this I'm heading to the local junk yard to find a cab to use for R&D work.
