No Wait To Start Light
- Replies 5
- Views 24.1k
Mopar1973Man 2 posts
BCole99 2 posts
dripley 1 post
This is my first post and I have been looking around on here but haven’t found anything like my problem. I'm looking for any help. I have a 99 Ram 3500. Some times when you turn the ignition switch on the wait to start light comes on and the lift pump does not but the truck will start immediately. I checked the voltage at the stock lift pump connector and their is 6-7 VDC until the truck is started then it jumps to 12 VDC. Other times when you turn the ignition switch on the wait to start light does not come on and the lift pump does not turn on and the truck will crank but will not start. After about 15-25 seconds the wait to start like and lift pump turn on and the the truck starts up and runs fine. I checked the voltage at the stock lift pump connector and theirs is 0 VDC until the wait to start light comes on. I have no check engine light but have codes P0380, P1693, P0123, P1694. The mechanic at the Transmission shop (after they rebuilt the transmission) tried a new TPS and said the new TPS did the same thing so they reinstalled the original TPS. He said the voltage at the TPS would steadily climb until it tripped the over volt then the wait to start light and lift pump would come on. He also thought it might be a bad ECM or PCM but wasn’t sure, but checked and cleaned all the grounds. I found and repaired a shorted wire at pin 5 of ECM. I also sent the ECM out for repair and got it back today. Before I installed the newly repaired ECM I completely cleaned all 4 battery connectors. When I turned the ignition on the first time the wait to start light came on and the lift pump turned on for about 1 maybe 2 seconds so I bumped the starter and the lift pump ran for about 30 seconds. Then I started the truck, it started fine after letting it run for a minute. Then I shut it down. Then I turned the ignition switch on and had no wait to start light and no lift pump. Then I bumped the starter and no lift pump but started fine. I checked the codes and had P0380, P1693. After some searching on here I found some stuff to check and found the Yellow/Black wire at the Intake heater relay disconnected reconnected wire. I turned ignition switch on and no wait to start light and no lift pump cleared codes then cranked fine rechecked codes and had P0123, P1693. Turned truck off, cleared codes, then turned ignition switch on no wait to start light and no lift pump but started fine and no codes. I’m thinking I have an electrical glitch somewhere but not sure where to look next. I’m thinking about ohming out every wire from the ECM to where they go. I want to check the connector at the TPS for corrosion and check all those wires. I’m also wondering if my PCM might be messing up and if so could it have messed up my ECM again? Any suggestions would be greatly appreciated.
