Update with the article for the install
Just a small teaser,
I am putting together an article, but in the meantime.
Morimoto mini h1 bi xenon swap to resolve the poor 2nd gen lights.
Edited by Me78569
  • Replies 53
  • Views 7.8k
  • https://www.theretrofitsource.com/complete-retrofit-kits/universal-kits/bi-xenon-morimoto-mini-stage-3-kit-h1.html#.VkvFePmrTs0   Clear none fluted lenses are a must as I found out haha.
  • The world has changed around me.
  • ill get some pictures tonight for you.  Last night was not as impressive as I would like due to the oem lenses distorting the output.
yea I would be curious to see what they have setup.
On Wed Nov 18 2015 08:26:31 GMT-0600, Mopar1973Man said:
So if a person bought a set of the clear lens head lights and retro fitted those into then it would work exactly how you want it. Correct?
http://www.protuninglab.com/94-01-dodge-ram-euro-headlights-black-ks.html?utm_source=googlepepla&utm_medium=adwords&id=140845616938
94-01 Dodge Ram Pickup Euro Crystal Headlights With Corner Lens - Black
I'm running these they are from Anzo and fully adjustable. They create a narrow beam. I will be trying to go with LED head lights soon so I will try and keep yall up to date on that project.
EBay has some good quality sport light housings for 140 shipped
Got them into the new housings.
I am gonna mount some 9004 in the high beams and run them too since halogens do a good job of throwing light.
You could also eliminate the moving parts abs use your fancy lights as high beam and run low beam halogens.  Probably not necessary though.
Nope the biggest perk to the projectors is the extremely wide beam of light.  the halogens do a better job of the throw of the light.
On Sun Nov 22 2015 08:39:41 GMT-0600, Mopar1973Man said:
Ok. So there is 2 people with them. Now lets see some good night time distance pictures. Nick has shown 2 pictures facing a wall. I want to see light distance...
I will try to get a shot of my LED headlights as comparison once I install them.
Just an update I ran the LED headlights only to find out the position of the high beam LED was incorrect which caused the light to go wider rather than further. So I'm currently back to upgraded Sylvania Halogens.
Good to know.  I figured the light source location wouldn't match the halogen bulbs, but the proof is in the puddling.
I am very happy to report that I have my lights aimed nicely now and WOW is all I can say.   very happy.
Picture of the high beam if you can I'm curious.
  • 4 weeks later...
Well I tried to get some pictures, but it seems I don't have a camera that can adjust to show throw on the lights.
update with the article
Edited by Me78569
