- Replies 8
- Views 1.9k
Botlebruiser 4 posts
Me78569 2 posts
Haggar 1 post
Hawkez 1 post
New Issue: After I replaced the multiswitch on the console everything was fine. My buddy was behind me a few days later and said my brake lights don't illuminate when I hit the pedal. I checked all my fuses and my brake switch twice. They will light up the first time I hit the pedal then they don't light up anymore. Anyone have any ideas? After I hit the brake pedal once I don't get anything. I'm guessing all of these issues are tied together in some way.
Resolved: My 3rd brake light switch fixed the issue. The first two must have been bad. I finally got one from the dealership(it was actually cheaper than O'Reiley's) and its fixed.
I hooked up my buddies trailer this morning with his 4wheeler on it so we could use it to go hunting. I plugged the trailer in and went to check my lights and none of the trailer lights worked. I hit one of my turn signals and neither of them work. It doesn't make the clicking sound or show the indicator lights on the dash even with the trailer unhooked. My flashers don't do anything either. My brake lights will light up with my running lights turned on but nothing happens when I hit the pedal. I had to replace the fuse under the hood for the brake lights but it didn't look like any of the other fuses were bad. I am going to check the bulbs in the morning and update this thread.
Obviously there is something very wrong with the wiring on this trailer. I'm sure it's a pretty major ground issue or something like that. I've pulled a couple other trailers and not had this issue. I'm curious if anyone has seen anything like this. Any suggestions are welcome as my truck is sitting at this point until I figure it out. Thanks in advance.
Edited by Botlebruiser
