Disarming airbag in the old Caprice
- Replies 13
- Views 3.6k
Mopar1973Man 5 posts
Ilikeoldfords 5 posts
Wild and Free 2 posts
CSM 1 post
Sounds like new car roofs need a cut here mark like military aircraft.
Pretty simple really. Just unhook the battery and leave the vehicle alone for 15 minutes minimum. The entire airbag system should be disarmed after that. Just make sure no one is inside the vehicle wh
That's standard protocol with the fire dept is get to the battery and cut the ground (negative) before attempting to enter or remove a patient from a vehicle. The time frame can be shorten but general
Hey guys. I am working on the old chevy again. I am going to be replacing the turn signal cam and ignition switch. I pulled off the front cover on the steering wheel and it has an airbag!! This is a 1992 Caprice classic.
Does anyone know what the disarm procedure is for this car? I dont really need an airbag going off because I unplugged the wrong thing.
Thanks for any tips!
