- Replies 36
- Views 12k
If cost is main concern just go s472 or even a ht3b.... Best setup on 3 sets if twins I ran was a He351cw/s472 S475 with a 96/1.32 are used as they are box turbos and cheaper. My 475
Hey to some of us spending that much makes sense! I think you'll hate the lag of the s475/96/1.32 with the hx35. They just do not match each other well. I had a buddy try it and all he succeede
No... No racing for the truck. I just tow with it and drive it around town. The only racing involvement it has is to tow the race car to the track... LOL I really don't have a specific goal for H
OK... So I have some down time for the Christmas season (intentionally scheduled). My plans are to go ahead with a twin turbo setup. The setup that I'm currently running is 100hp BD injectors (I'm not 100% sold on keeping these...I may go with 125's or 150's), Smarty S-03, FASS DDRP (no fuel pressure problems currently, but I plan on upgrading to a larger FASS), and I plan on, most likely, stacking an Edge with the new CTS2 with what I already have. So my question for those who have gone before me is this:
Which bottom turbo should I go with? I plan on using the HX35 that I currently have as the top turbo. I want a fairly quick spooling setup, and I use my truck most often for just driving around, but I do tow with it once in a while...usually fairly heavy. It's not necessarily my daily driver, either, as I do have other cars. It has been recommended to me to go with an S472 with 83mm turbine and 1.10 housing. This seems a little on the small side if I go with larger injectors but, then again, so does the HX35 up top. I see a lot of guys going with an S475 with 96mm turbine and 1.32 housing. These seem to be fairly cheap, too.
How should I mod the wastegate to work best with the compound setup. The turbo I have right now is currently unmodified...
I really don't want to change the top turbo. In my opinion, that would price this project right out of the realm of feasibility. I can afford it, but at the end of the day, it's just a 2nd Gen 24V, and spending that much on a turbo setup just doesn't make sense.
Opinions...?
