Old High idle kit and P0113 code
- Replies 4
- Views 1.8k
Me78569 2 posts
Mopar1973Man 1 post
Explosives87 1 post
I have the older style of high idle kit and the other day that I was diving and got a p0113 code. Pulled the code and found out that it was the IAT temp voltage was to high. I tired with two different code readers and couldn't clear the code. I pulled my high idle kit off and plugged the factory harness back into the sensor and was able to clear the code and have gotten the code back. Is there anyway that I would be able check to see if I have a short of some sort in my wiring or check the switches? Also from time to time I would select the 6 cylinder and then it would switch over to the 3 cylinder high idle with out me selecting it. Would like to have my high idle back up and running.
Edited by Me78569
