How much would all of this have cost?
- Replies 3
- Views 1.6k
Dieselfuture 1 post
CTcummins24V 1 post
The_Hammer 1 post
I got to thinking about all the work I've done to my truck in the last 6 months and started to wonder how much I would have paid in labor if a shop had done everything.
Project #1
Installed DOR track bar.
Project #2
Removed timing case cover and replaced seal.
Tabbed the KDP.
Cleaned, applied Loctite, and torqued timing case to engine bolts.
Removed injection pump, replaced tappet cover gasket.
Set pump timing to 16.5°.
Flushed cooling system
Project #3
Replaced belt tensioner
Project #4
Replaced wheel cylinders with GM 1-ton pieces.
Replaced wheel seal.
Replaced rear brake drums and shoes.
Flushed brake system.
Project #5
Replaced A/C evaporator and heater core.
Replaced HVAC unit foam.
Project #6
Replace transmission lines.
Project #7
Removed transmission.
Removed valvebody.
Inspected transmission, replaced anchor and apply lever with billet pieces.
Installed new valve valvebody.
Installed transmission.
Road test vehicle, adjusted T/V cable and front band.
Project #8
Replaced steering gear output shaft seal.
Cleaned power steering pump screen.
Flushed system.
Project #9
Replaced front shocks.
So, without spending too much time running the numbers how much do you think it would have cost in labor alone for all of the work listed above?
Edited by The_Hammer
