Straightening out wiring harness.
  • Replies 22
  • Views 6.6k
12 hours ago, The_Hammer said:
I do have some questions about the fusible links, which the truck currently has none of.
Is there supposed to be one in-line of the power wire going to the shutdown solenoid relay?
What about for the starter relay?
Should fusible links be two gauges smaller than the wire it's protecting?
The Fuel Heater and FSS both get 16ga fusible links.  I don't know what the grids get.  The starter I'm not sure about, if it does, it's under the insulation.
I'm with Nick on this one.
Edited by Cowboy
The fuel heater and it's wiring are gone. I've got a 16ga fusible link for the FSS, I wanted to make sure it was correct before installing it. The starter relay power wire has been replaced somewhere along the line so there isn't a link installed. The grid heater relays do in fact have links. I'm wanting to make sure everything is set up right. I've had wiring burst in to flames on a previous vehicle before, due to shoddy wiring by the previous owner.
Edited by The_Hammer
