2001 dodge ram 2500 v8 magnum 5.9L 4x4 5speed
- Replies 7
- Views 3.5k
Me78569 3 posts
mannyjr 2 posts
Mopar1973Man 1 post
Dynamic 1 post
So i recently come to owning this truck as in description and ive been having an issue with the idle while in neutral and if i press the gas pedal slightly or let off, here are some examples the truck will idle real low almost to shutting off then will idle high to prevent its self from shutting off, another example is say im in a drivethur or at a light if i pull up a bit and stop it the rpm will jump up to around 2000 or 3000 varies, also while at a light if im in first or second when i start to go the truck will not accelerate nor does the rpm move untill if i either floor it or put it in neutral and rev the engine then it will start acceleration and thats about all my problems at the moment, ive checked and replace my o2 sensors, iac, check the throttle body and the senor on it and now im at a complete lost, if anyone has any advice or recommendations id be gladly to accept and try
Edited by mannyjr
