Anymore air required ?
Going to be changing fluids and such on my new to me 2002. With only an edge juice is there any need for anything more than a regular parts store replacement paper filter for the air box ?
I know most bang for buck would be BHAF. I like the stock look and would prefer to keep the stock box(don't see any cracks in it) If the regular fram filter isn't adequate for the Edge juice i was thinking about the slightly more expensive route of an AFE dry factory replacement for the stock airbox.
Thanks
  • Replies 3
  • Views 1.4k
  • stock is fine.
    Also double check for deforming of the stock air box. This is the reason I gave up. I was happy with the stock air box but when you can spray WD40 on the top lid and find dust trails from the s
Also double check for deforming of the stock air box. This is the reason I gave up. I was happy with the stock air box but when you can spray WD40 on the top lid and find dust trails from the sealing lip you need to grease the filter seal from there on out or convert to BHAF.
Ask JAG1 about his box he had to modify his for this reason. I know the clips he bents to clamp tighter and something on the box to aid in clamping.
