- Replies 21
 - Views 20.3k
								bluegoat01 8 posts
								Mopar1973Man 5 posts
								TFaoro 5 posts
								JAG1 3 posts
Popular Days
I've seen this on my last truck I worked on. I had 1995 Dodge that the owner claims the previous shop installed a power steering pump. Sad to say the pump didn't last very long because the prev
I'm glad you got and didn't give up. That's the way somethings go at times, I think you just saved thousands of dollars.
Yeah but during change up you might of loosen up some debris and now the hydro-booster is partial plugged up. More common than you think. This is why I always suggest doing a full system flush
Ok I posted a while back about some issues I was having with the hydroboost system. The power steering pump went out and I replaced it. Then the hydroboost started making lots of noise, and shuddering when the brakes were applied. I would lose power steering altogether at an idle, but all this only happened after about 5 minutes of driving. Today I finally broke down and swapped the hydroboost I still have the same problems.... I'm at my wits end here wit this thing! I don't know what else to do. Btw it an 01 2wd.
