99 suspension
Looking to change sway bar or just the end links any recommendations on the 1999 I heard it's not that bad of a suspension I have the steering brace new shocks ball joints seem tight just at high speeds and tight lanes i gets a little white knuckles
  • Replies 5
  • Views 2.7k
I'd look at getting new sway bar links first.  Make sure they are long enough to support your 2" lift.
See how the truck handles from that point.
end links are an easy and fairly cheap install. If your getting swaying issues at higher speeds, that sounds like track bar to me.
I going to order sway bar end links I have a 2 in leveling kit do I need the adjustable away bar and end links  I'm also going to change the track bar any suggestions on where to purchase these parts thanks
Edited by ebbtide357
i'd get adjustable links and track bar for any amount of lift.
the more the lift the truck the more the axle will shift, .5 inch to 8" doesn't matter the axle will move.  More the bigger the lift.
Diesel Auto Power is a good spot for most of those parts. If you read the description on the end link they'll typically state the range of lift they can accommodate. As far as track bar, I'd say just pick whichever one is adjustable and fits your budget.
