- Replies 4
- Views 2k
JOHNFAK 1 post
dripley 1 post
CSM 1 post
Buzzinhalfdozen 1 post
Popular Days
I dont know what gauge the metal is, I do know you can get small squares of light gauge stuff at Lowes and maybe HD in the hardware section. Probably not the most economical but handy.
Rust? Take a gander at this... If you don't kill the rust, it will just get worse. Welding may be best, but it is by no means necessary if done right. I'd look at some of the underbod
18 or 20 gauge is pretty easy to work with. Obviously avoid galvanized if you're welding it, any bigger hardware store should have a piece of sheet metal that'll work. Nothing special required, I made
Dumb question.
If I wanted to patch part of a panel on the underside of truck by the kick panel .....
What guage steel and can I just pick it up from any hardware store ....
Nothing special ?
