Codes p-0237and p-0177
- Replies 11
- Views 2.9k
Dieselfuture 5 posts
Me78569 4 posts
klcammie 2 posts
I had a map code when the oil pressure sensor died and shorted. I would check the 5v lead on the map wire.
There are a few things that pull a small charge. Like the clock in radio and the memory for the radio.
Just take out fuse, then no hole in dash. Here in southeast Ohio no good radio stations. Even when try to listen to **** much ads.
After I took my batteries out to charge them, the next day I put them back in and now I got codes 237 and 177. I'm going to unhook them over night again and try resetting the apps, I heard that that could be the cause. Any other ideas? All I did is took batteries out charged them over night and put them back in, and did apps reset. All connections are in good shape, and I don't even have the factory fuel filter anymore just the fass 150. I'm hoping it's not the ecm. Thanks for the help.
