- Replies 18
- Views 4.8k
Wild and Free 6 posts
Cummins2001 6 posts
Mopar1973Man 2 posts
mr.mindless 1 post
Ok. The 4x4 works sometimes and not other times. The light rarely comes on when in 4x4. To start things off I was out driving in some snow this winter in 4x4(or at least the lever was in 4x4) and I was going up a small hill and all of a sudden the 4x4 quit working. I never heard any grinding or anything. 4x4 hi and 4x4 lo was both the same. I moved the lever from Hi to Lo several time and then It started working. So I figured the linkage was out of adjustment. So next day I adjusted it and it seemed to work although the light was not on. Couple weeks later I ran into some mud and got it stuck. Turns out the 4x4 still was not working right. After moving the lever from hi to lo several time it finually worked and still there was not light. I backed it up out of the mud and stoped and put truck in Park. Got out to get something and got back in and put it in reverse and I was in a little wet grass and and the 4x4 quit working so I was just spinning. I have heard alot of people say "Oh you have a vacuum line leak". But they say if it leaks then your cruise control will not work. But my cruise control work great, no problem. Any ideas on what is wrong and how I can fix it.
