- Replies 10
- Views 2.8k
Pipeline22 5 posts
Wild and Free 2 posts
CSM 2 posts
Dieselfuture 1 post
Just unplugging the comp will cause codes and check engine light unless you completely take it out of the circuit and plug the OEM sensor harness back together.
Thank you for updating and letting us know, I did hear a rumor that some of these 24 valve heads if worked hard during their life, need a valve and seat job every so often. And some heads crack, it p
My 02 cummins 2500 4x4 with nv4500 has a rough idle or like a miss after the truck is warmed up. It smooths out if the AC kicks in or you let the clutch out just a little as if you were to roll ahead a bit. The truck has a new vp44, TPS, and FASS titanium pump. I've seen this problem posted on other forums but nobody had a fix to the rough idle. Anyone have this problem or have a fix for it? Any help would be greatful.
