- Replies 10
- Views 3.8k
cummins 4 posts
Mopar1973Man 3 posts
dually 2 posts
Guateman 1 post
Hey Mike , wanted to ask your opinion on something, I had send you this link last month http://www.cumminsforum.com/forum/98-5-02-powertrain/260716-vp44-electronic-fix.html . So I did it on my second truck that I have been working on because I was getting dead pedal and the code P0216 so I gave it a try and now I have been trying to turn the truck on and it wont start. This is what I have done so far : I loosen the banjo bolt on the vp and fuel did came out from there with a lot of pressure ,then I loosen injector line 3,4 and 5 and I am only getting fuel on injectors 4 and 5 ,on 4 is were it comes out the most and on 5 it only drips . Could I have messed up the pump ? I tried it because I knew that it was going to fail sooner or later so I took the chance . What should I do ?
