going to replace apps, now I see that a screw needs to be turned to take out the slackdoes any one have a picture of this screw, in the front I presume, thanks
  • Replies 26
  • Views 6.2k
Posted Image
If you are using timbo apps this is the one.Use a volt meter soon as it statrs to go up turn it 1/2 back and your done.Just did this yesterday.
Posted Image
This is the back.If you are NOT going with timbo apps and you diddnt buy the entire pc.Then you have to turn this pc to match the voltage on the white tag you see here.This one here says 0.553.So thats what you need to see on the voltage meter.And this is done by rocking this clock or counter clock wise.If you DONT have a timbo apps DONT turn the screw in the first picture.Edit :hey Michael I was kinda racing you:tongue:.No work today and to much coffee:hyper:
(Revision to this)
You can obtain the voltage setting using the set screw on the other side there is no reason to mess with the mounting screws and twisting the sensor back and forth.
If you DONT have a timbo apps DONT turn the screw in the first picture.I was kinda racing you:tongue:.No work today and to much coffee:hyper:
Join the club... 2nd cup and wound up tight now...
But as for setting the voltage on a old sensor. Typical the sensor is sold complete assembled and calibrated so you don't need to adjust a new sensor. Also after playing with mine I thing people are confused about the voltage mark on the tag. This is the voltage where the On/Off idle switch trade out. So if your ABOVE this voltage then the APPS is OFF IDLE and if your below this voltage then your ON IDLE. So if you voltage is a bit low is fine. But if you voltage is above the printed tag then systems like high idle, exhaust brake, transmission shifting, etc don't work properly because the ECM/PCM always assume your pushing the throttle.
I know I need to revise this way of thinking and post a update in my APPS write up...
http://forum.mopar1973man.com/attachment.php?attachmentid=970
Thamks for the pictures, really , thanks for the help, unfortunally I did"nt see the timbo one:banghead:got the one fron geno"s garage,:cry: timbo"s cheaper I see Now, wonder if I will have to set that one like Timbo"s?, I guess I"ll see when I get It, may be just the reset procedure, again thank you
Thanks Michael for correcting me i diddnt know that.So what did you get then?Did you get the bellcrank like the one in the picture?Or just the sensor?
just the sensor
Here is the Timbo APPS install write up... http://forum.mopar1973man.com/showthread.php/1527-Timbo-APPS Making a temporary sticky so I can add it to the archives...:smart:
, do you think the genos sensor would install the same as the timbo
ok Dually, I appreciate your time answering my questions, and to Michael too,
so the install is the same as the Timbo, it will be here monday
ok, thanks for your help, I think Geno"s sells the Timbo sensor
I am a bit confused yet as the Timbo apps still had to go through the key on pedal to the floor and up key off a couple of times. So if it doesn't need to be calibrated why does this calibration sequence still need to be done just like the old OEM style? I asume the ecm/pcm needs to see the new voltage values but would it need to be redone after unhooking the batteries evey time like the oem or was it a one shot deal? I have seen no one else question this and details quit after the initial recal sequence.
It does.When you install you should get something like .620 (Just a example)Then you put a volt meter on.When is starts to go up you turn it back 1/2 turn.This will take up the slack in the pedal.Now the timbo apps is set.The pedal to the floor is to tell the computer the new voltage.Thats how i see it.I dont know about the reset.
turning back the screw a1/2 a turn counterclockwise, will this bring the volts at or below .533what if you turn it a 1/2 a turn and it goes to lets say .543, would u keep turning it back til lit goes below .533, thanks
turning back the screw a1/2 a turn counterclockwise, will this bring the volts at or below .533 what if you turn it a 1/2 a turn and it goes to lets say .543, would u keep turning it back til lit goes below .533, thanks
Just start going up slow, mine jumped a few numbers and i went back 1/2.I just did what it said because there is no magic number you are looking for. Just a 1/2 back.When i turned my timbo apps back per instructions.The voltage did not drop much.I used a screw driver with a 20 torx bit.It was easy to turn it up and back down looking at the handle to see a 1/2 turn.I went real slow.But to each his own in reguards to tools.
