Hard Start if at all, lots White smoke, has new vp44 & injectors
- Replies 8
- Views 7.1k
Mopar1973Man 2 posts
tonyjsan 2 posts
dually 2 posts
SASQCH 2 posts
Buddy of mine has 1999 dodge truck, 5 speed 4x4. He replaced the vp44 & installed new injectors, the vp44 had failed, had that 16xx code, can't recall the exact code. The truck is hard starting, if it starts at all, if it does it idle's smooth but blows thick amounts of white smoke (i'm assuming lots of unburned diesel fuel) and the pedal is dead. White smoke does not go away.Several things I thought of vp44 installed wrong (timing key), injectors and/or connectors torqued wrong, over flow valve ???? I'm grasping at straws here, any suggestions appreciated.Thanks in advance.
