Airtex pump to Airdog FRRP help!
- Replies 4
- Views 2.1k
Mopar1973Man 2 posts
sooxies 2 posts
Popular Days
Call Eric at Vulcan Performance he'll have the fitting your looking for. Won't be the same but I'm sure he'll have something.
Easy way. Empty or nearly empty fuel tank. Grab two cam buckle straps. Strap the tank in place. Remove the two band holding the tank. Ease the tank down enough so you can knock the collar loose with a
Replacing the Airtex with an FRRP 100. The Airtex pump does away with the factory line that has a banjo type setup and just uses the quick connect fitting. I need this line for my FRRP to work but it is expensive....are there any cheaper alternatives? Assuming the P.O. just threw it out with the factory pump. I wish Airdog did the same as Airtex and did away with the banjo setup. Part number 8 in the photo....the line that has the support bracket on it.
