No vehicle speed on IQuad
- Replies 32
- Views 6.7k
martinique78 15 posts
Me78569 9 posts
Mopar1973Man 8 posts
Good news is I was able to tap off the ford vss signal and tie it into the wire that use to go to the dodge abs unit and now I have vehicle speed on the iQuad and it's spot on with the ford speedo and
Sure! Ford has many points on the vehicle to pull vehicle speed from. Ford uses a tone wheel on the rear diff to run the speedo, cruise control, and ABS. I found the easiest point for me to gra
Speed is reported by the Dodge ABS computer not the the PCM. You would have to setup the Dodge ABS computer just to get speed. The speed sensor in the transmission is only for shifting not road speed.
I just finished up my Fummins swap on my 2004 Excursion v10 gasser. I installed a 2001 24V along with the 47RE transmission being controlled by the Dodge PCM. I installed all the required wiring and the truck runs and shifts fine however I dont have MPH on my Quadzilla iQuad display. Does the iQuad get the vehicle speed from the cluster that is no longer attached or does it get it from the transmission speed sensor?
In the beginning i couldn't get the trans to shift. I started poking around on the trans harness and found that one of the wires going to the transmission speed sensor was cut. I repaired that and now the trans shifts like it should however I'm still not getting a MPH signal to the iquad.
I'm running V2 base tunes on my Adrenaline.
