Stalling
Now that it is warming up my truck seems to stall when it is warm. First thing in the morning it is fine but after a 10 to 15 min drive it will stall when put into gear. It also has a bit of a lope after starting when warm. No codes no change in fuel additives. Replaced vp44 2 years ago with no problems after. Any ideas?AkFred
  • Replies 4
  • Views 2.4k
What kind of lift pump do you have? Whats your fuel pressure?
Now that it is warming up my truck seems to stall when it is warm. First thing in the morning it is fine but after a 10 to 15 min drive it will stall when put into gear. It also has a bit of a lope after starting when warm. No codes no change in fuel additives. Replaced vp44 2 years ago with no problems after. Any ideas? AkFred
Is it like this??? http://forum.mopar1973man.com/showthread.php/1811-Can-the-idle-speed-be-adjusted?p=12780&viewfull=1#post12780
Tell me about your truck. Is it auto or manual trans? What modifications does it have? Would be helpfull to put all that info into your signature like most others on the forum. I'm having a similar problem and I'm in Anchorage, we need to compare notes to perhaps find a common thread.
I have a fass 95 fuel pump and fuel gauge(18psi). Other gauges pyro, boost, trans. Everything is good. I will know more when I get back into country, because it broke down 45 minutes before I had to be at the airport. So stalling is not a real issue right now. I will have to check several things upon my return.Oh well ..
