Engine squeak, NOT serpentine belt
- Replies 7
- Views 3.9k
Cronus577 4 posts
Mopar1973Man 1 post
TFaoro 1 post
CumminsTech 1 post
Popular Days
Fan pulley bearing? Pull the belt and check all your pulleys for bearing looseness. There is nothing under that valve cover that would squeak. Maybe the vacuum pump or power steering pump that is the
That's an important clamp!! Make sure you don't have deep wear grooves in the lines.
Was sitting at idle in the parking lot before shutting off the engine. I noticed a squeak under the hood, I know my serpentine belt was squealing a week ago after hitting a big puddle and thought that was the case, so I popped the hood and had a listen and it's not coming from the belt. It's loudest on the driver's side around the valve cover. Is there anything under the valve cover that would make a squeaking noise, injectors, valve springs, could it possibly be the vp44? I don't notice anymore smoke than usual, loss of power, and there's no blow by
Edited by Cronus577
