- Replies 16
- Views 7.7k
TFaoro 9 posts
nukethenazis 4 posts
Wild and Free 1 post
trreed 1 post
Dumb thought after resolving a strange lope issue. Check your valve lash maybe too much gap.
Must be a Deutz engine, I know Gehl uses them on their older machines. Couyld be a hydraulic issue too, wouldn't spend too much time on the engine until you do a hydraulic tune up first, if the pressu
So I got some work done on the skid steer this weekend. I replaced all of the fuel lines (many were cracked) I pulled the radiator and fan assembly back and removed the timing cover - The belt ha
Hey guys I figured I'd post this here and see if anyone had some thoughts.
I bought a Gehl 5640 skid steer with the BF4M2011 turbo diesel engine.
When I start it, it idles perfectly smooth for 2-3 seconds then begins to surge.
As I rev it up when cold it still surges until the rpms are over half throttle.
After 20min or so of running when the engine is up to temp the engine surge goes away at all rpms.
So far I've checked all of the fuel lines and replaced the lift pump.
Does this sound like a governor issue? Shutdown solenoid? Fuel pressure? Springs on the throttle cable or rack?
