Helpful Spreadsheets
- Replies 18
- Views 6.1k
ISX 9 posts
guesswho512 4 posts
Mopar1973Man 2 posts
AH64ID 2 posts
I figured I would make a sticky for these. They serve me well many times over so I want to make sure you guys can always get to them to help you out. I will be adding more and more to them all the time as I think of things to add.
The Excel file will convert over to anything else, and I have now made it work on any free program, let me know if it doesn't and I will reformulate it to keep it universal. I haven't decided whether or not to just add pages to one document and you guys just replace the new thing with your old one, or just keep adding new ones. Adding pages to one file that you guys can keep replacing and therefore "updating" it seems the most logical. Will also keep new people from having to download 10 files.
I am just going to update this #1 post over and over so you won't have to dig through this thread if it ends up getting long.
If you have any requests or ideas, PM me them or post on the thread.
This current file contains sheets for:
Power Calculations (Volts/Amps/Ohms/Watts)
kWh Costs (How much it will cost you to run something)
Conversions (Temp/Speed/Pressure/etc.)
Bolt Torque (Bolt Tightening Torques, where not provided by OEM)
MPH-RPM Calc (Figuring speed based on gear ratios)
Area and Geometry (Right triangle and circle stuff)
Engine Calculations (Bore x Stroke and some other neat things)
Mileage Statistics (More details than just MPG)
If you find any errors, let me know.
For those wanting to change some things, password on all of the sheets is "dodge".
This file will work with Excel and OpenOffice. If you are using Google Docs, use the GOOGLE file.
Note: Google Doc users will experience #DIV/0! errors due to it's limited capabilities (meaning I can't make it hide the errors). The spreadsheet will work the same but when things are blank, it will give the error, this is all how it is supposed to work and there are codes to make it blank instead of showing the error code but the IFERROR code does not work in google docs and I don't know what does so you will have to ignore the codes.
Helpful things.xls
Helpful things GOOGLE.xls
