- Replies 4
- Views 2.2k
Mopar1973Man 1 post
Nekkedbob 1 post
015point9 1 post
jlbayes 1 post
I just purchased my first trailer that will need a charge line ( my last two had solar and 110 ac charging) and I noticed that the charge line in my truck has no relay that I can find. This concerns me because if the grids turn on they will pull current from the batteries including the trailer when plugged in. Being that the grids pull 100 amps each and the alternator will not even supply what is needed for one grid at idle. I my have heard wrong but I heard that our trucks had one just for this reason and so you cant draw from the truck batteries when parked and draining them down. I found the relay for the clearance / running lights but none for the charge line. Has anyone pulling a travel trailer had any problem with this or is there a relay I missed.
