- Replies 15
- Views 4.2k
Mopar1973Man 5 posts
ISX 5 posts
thebullet83 3 posts
dobienut 2 posts
So while my truck is in the body shop i'm sitting back thinking of the things I want to fix or replace on it during this overhaul i'm doing on it. For the past 2 years i've had a psi gauge taped fast to the steering column with electical tape and if i'm dumping this kind of money into a body job, shouldn't I be able to spend some money and get some gauges? There lies the problem
,right now i'm running a Quadzilla XZT module and only gauge I have is fuel psi. I've been wondering if I should go with a 3 pillar set up of fuel, egt and boost, or should I ditch the XZT and buy an Adrenaline with pulse and get the gauges that way. I know, more money then the pillar set up, but I also get the power upgrade with the module. Then I look at the Edge with attitude, only that can't monitor fuel if I understand correctly. Wondering if either programmer will be more than my turbo will take (stock), wonder what other issues i'll have. In my head I kow what the smartest thing to do is..3 pillar and save my clutch and turbo, but i never said I was very smart!
I notice the tailpipe is rotted off my truck too, I have a buddy that has a new aftermarket one I can buy for $25 (he went 4"), or I can upgrade to 4" too for about $300, which sounds nice and of course helps work a bit better most likely. Sigh.....to many options, not enough money, to hard to decide
Any opinions from people running any of this stuff
