Plugs , back up light switch
Is there anywhere to get the same type male and female plugs for the back-up(neutral safety) switch?
To make a inline plug-in pigtail so I dont have to cut the factory harness wires to splice in a remote aftermarket back-up light on/off switch
99468d1501402804-i-need-to-find-neutral-
Edited by GSP7
  • Replies 4
  • Views 1.8k
Wow,
For some reason there is not much info on the flat connector.   (I guess they only used it a couple years.)  Chrysler didn't put info in the FSM on exactly what connector.  They used a round connector for years on the same switch.  Lots of info on that.  But not much on the newer flat one.
For the male end, when you figure out the series of the female  you may be able to find the compatible male.  (it may have never been made though.)
Good Luck!
Hag
