So this must be where my problem lies..
- Replies 4
- Views 1.8k
ISX 2 posts
Mopar1973Man 1 post
LiveOak 1 post
Last trip to St. Joe State Park to ride dirt bikes, well and the time before that, trailer brakes have stopped working. In the morning some of the lights on the trailer weren't working but magically did when enough things were kicked. So I knew it was kind of a mess under my truck but I didn't even think it was *MY* truck that was the problem, but I stand corrected now. You can see in the first pic, or maybe you cant, but the bigger connector has 3 wires going into it, 1 cut off, then only 1 wire leaving it ( I know it looks like 3). There were about 5 other wires going to nothing, 5 more wires that had been physically split by corrosion (including trailer brake wire), and enough butt connectors to fill up the Ace Hardware bin. I cleaned it up and got rid of all the BS as you can see in the second pic. I got some light wires wrong like the running lights flash with the turn signal, but the trailer brakes work now! Have to make it all perfect tomorrow.
