Word of thanks and some questions
- Replies 4
- Views 1.5k
Mopar1973Man 2 posts
Marcus2000monster 2 posts
Recently I purchased a mopar1973man High idle kit for my truck. I must say I'm pretty pleased with the design and all! Id like to say thank you to @Mopar1973Man and @Me78569 for their time and investment to produce the switches. I do have a couple questions... 1. Apparently there is a delay from when you switch to high idle till the time it actually starts to high idle? 2. When switching from Off position to MPG position my truck engine skipped a beat and did a pretty good miss. Is this normal? Heres a few side notes. The only good place I could find to route the harness thru the firewall was thru the hole that the hood latch cable goes thru. But the switch would not fit in the hole! All you have to do is get a utility knife with a sharp blade and round off the corners of the plug and try to fit it thu until it goes. I shaved a fair amount off but not enough to hurt anything or cause any issues. Secondly ill post a picture of the location of my switch. I really like the location because thres no chance of bumping your knee against the switch and breaking it or something....
