Wait to start light and no power to lift pump
- Replies 11
- Views 6.7k
dripley 4 posts
Petelightning 4 posts
Mopar1973Man 3 posts
So I replaced the fuel lines from the injector pump to where it T's off to the back of the motor and then the fuel return line. I went to replace the fuel pump with a drp2 but the connections are different (mustvhave been replaced at some point)
Anyways. I go to start it after and nothing. No wait to start light and no power to the pump. No codes.I wired the pump to the battery and it will run. I also tried to put in a new relay switch drawing power from the brown/white wire going into the PCM and still nothing.
I then replaced the ECM with a good used one and at the same time replaced the alternator in case there was any noise. Turned it on today and nothing. Still no power to the loft pump and no wait to start light and still no codes.
Anyone else have some siggestions?
Is it relatively easy to take out the whole wiring harness to check for bad wires?
When I turn the key into the on position there is a pulsing type noise coming from beneath the battery. I think it's just the cruise control? (I unplugged that vaccum line due to a leak)
Thanks everyone. Almost at wits end here
