- Replies 10
- Views 1.7k
JPENNER79 5 posts
Mopar1973Man 4 posts
Dieselfuture 1 post
Hello I’m wondering if you can help me out. I have a 2002 Dodge Cummins 24V. Cold start issue. I checked fuel pressure going into injection pump and I'm at 16psi. Wide open throttle it drops to 11psi. So all good there right. What the issue is at -10 celcius it won't start but if I plug in and leave over night it starts no problem. My intake heater is working as the intake elbow is really warm. So it's a cold thing. When I tried starting at -10c without being plugged in I cracked fuel lines at injectors and no fuel would come out. But... next day when I plugged in she started right up no issues. Seems like when the eng block is warm it seems to hold prime but when it's cold it doesn't. I read somewhere that possible low oil pressure could prevent the injection pump from sending fuel to injectors. Any ideas?
