Lift pump not firing before start and after key bump
- Replies 15
- Views 3.4k
Mopar1973Man 7 posts
shanechrystall 6 posts
Dieselfuture 2 posts
Hey guys my rigs been acting weird electrically lately it sat for 9 months while I was saving for a new turbo setup.
Now that its up and running im having several what I suspect are electrical issues here are what I think may be the symptoms of my ecu going bad( rough idle at peak high idle rpm, lift pump not cycling when I turn the key on or bump it) I do have fuel pressure while the truck runs It takes longer to start now that I dont have pressure before start up.
I've read similar threads but saw no resolutions
The other issue im having is my od, it stopped going into overdrive by itself (lock up switch did the trick for a few months) now even in lock up it wont fully lock up tach only drops 1-200 rpms. I suspect a bad apps because of an intermintent dead pedal.
