The neighbor and I ripped apart the cancerous rocker panel hole I had today.
The spot weld drilling was no fun.
F6C02B9C-8B1B-4A0D-A234-22273C1AD4A2.MOV
Dodge screwed us in this deal.
There’s foam attached to the outer rocker.
Fitting the new rocker in.
Getting ready to spot weld in
Maybe be in bondo tonight
Ready for bondo.
Edited by Ben
Clean up clutter
  • Replies 8
  • Views 2.8k
  • I don't think so.    Plasma was never ever a consideration.  It stayed parked.    It was like an adhesive tape foam.
  • As soon as paint dries clear coat.    Water based takes a lot longer to dry.    3 coats of clear and it’s done.
  • fogged306
    fogged306
    If you live anywhere where they salt in the winter, I would highly suggest getting some fluid film or similar and spraying up inside the area you just repaired to coat the backside of the welds. I'd s
Edited by Ben
All done. Ready for paint.
A lot of work. Hopefully it's worth it.
Edited by Ben
I think someone sprayed foam in there, and to get them off I use plasma cutter works much better :thumb1:
I don't think so.
Edited by Ben
Water based takes a lot longer to dry. B89C645E-69F2-4980-ABBB-324026FA935D.jpeg.39efc9c9f65c9bdfb25cc2115c640ac7.jpeg
Edited by Ben
Nice job. You've got a skill for welding that for sure to be able to weld that piece back in like that. I'll keep you in mind when I get ready to squirt paint on the 1996 Dodge Ram of mine.
Lol. Thanks!!! That's all the neighbor. He is an awesome fabricator, body man,  and dirt jockey
I just do menial jobs, hand tools, and mix drinks.
His estimation we are carving into the other side in 2 years. Yay.
Edited by Ben
If you live anywhere where they salt in the winter, I would highly suggest getting some fluid film or similar and spraying up inside the area you just repaired to coat the backside of the welds. I'd spray it every fall to keep it coated. Even if you have to drill a few holes in the underside to have access and then seal it up with rubber plugs. The bare welds on the back side of that repair will start to rust from the inside out and will bleed through in just a couple years. I know from experience. I did mine when I built my truck and they started to bubble the paint in some spots about 2 years later. Now I have to redo it.
