Leaking transmission line
Hey everyone,My truck has developed a transmission line leak. It is from the fitting on the drivers side transmission line. (Looking up at it) I will try to post a pic. Anyways, I've read that those fittings suck, and was wondering if I can just replace it with regular transmission line and a hose clamp? Is there an o ring in these fittings that let go or are they just notorious for leaking. Any help would be great thanks.
  • Replies 3
  • Views 2.4k
Cut it flare it and hose clamp it just like the newer ones are. My 02 has a hose clamp on the hoses going into the cooler.
