Manifold Bolts
Assuming there are 6 bolts to mount the manifold to the block ?
If so - I am missing one ....... where do I get another - local parts store carry ?
thanks
---------- Post added at 02:56 PM ---------- Previous post was at 02:45 PM ----------
ok answer my own dumb question - yes it does and yes I am missing
napa doesn't have .... checking o'reilly's
  • Replies 5
  • Views 2.5k
Actually isn't it 12 bolts the hold the exhaust manifold on? Or are you talking about the Intake?
Yeah - 12 :)
6 top was the ones I meant ....... but 12 total plus the ones for the turbo (4).
Seems like My#6 top one is missing - and the bottom one is also loose ........ hoping this is the cause of my 'echo' comming through my BHAF/elbow.
Found a match at lowes - but guy said it wouldn't handle the heat on a manifold - I didn't think that would be right - but last thing I want is to fight with a broken bolt in the #6 port.
So off to junk yard today and pick up some ...... gonna look around whilst I'm there and see whats what - looking for new grill also.
Picked up a new polisher last week - gonna buff the heck out of my truck and see what happens - its almost 10 years old now - but hopefully put a bit of shine back into her.
http://www.harborfreight.com/7-inch-variable-speed-polisher-sander-92623.html
---------- Post added at 11:48 AM ---------- Previous post was at 05:18 AM ----------
mwaaa :banghead:
ok - 3 parts stores, 2 junk yards and eventually got the bolt at the "stealers" for $14 (with spacer).
The problem is - didn't fix my sound. :cry:
Going to have to redo the valve-lash adjustment - see if anything loose.
Any tips/ideas on how to check for a leak in the manifold ???? I guess I would have to pull it together with the turbo ? Wondering if there is a small leak/crack somewhere - either underneath or near that #6 since there was a missing bolt.
the ford house isn't any better. but my buddy's 94 GMC 3/4ton has the cheapest price for parts.
that would be my thought
I am thinking what you hear is normal sounds.
yeah - except the sound definately wasn;t there before - so kinda freaking me out. taking it to mechanic monday. Tried a stethoscope - hard to distinguish sounds. Closest sound I could find was when I had it on the injector lines when it pulses. But way to hard to tell if that was the same sound or just similar. Trucks killing me. Well - whadda-ya do. Mike/W+F - why do u guys have to live so friggin far away - considered a move to MO ? We have a good baseball team :thumbup2: How about I just fly one of you out here for weekend an put you up in hotel and you just go over my truck ...... might even be cheaper for me :lmao2: :banghead:
