- Replies 7
- Views 1.9k
Mopar1973Man 2 posts
Sycostang67 2 posts
JAG1 1 post
Sad part the water pump is purely a coolant flush issue. If the coolant was flush at a proper time you wouldn't eat the water pump bearing. I'm at nearly 350k miles on the OEM water pump on the Cummin
I'm working on my brother in laws 1994 Jeep Wrangler. The water pump bearings failed. I was draining the coolant and popped the radiator cap off and thought I saw little metal slivers inside it. When I got the pump off, I realized why. The bearing allowed enough movement for the impeller to scrape the inside of the housing as well as let the pulley rub the outside. Looks like I'll be flushing the motor really well and changing the rest of the cooling system. Radiator is pretty gunked and leaks a bit so it needs replaced anyhow. This poor kid can't catch a break either, in the last 200 miles he had to get the rear axle completely rebuilt when a C-clip broke and destroyed the gears. Right before that the transmission had to be rebuilt when one of the rings fell apart and jammed in the 3-4 cluster locking it in neutral.
Edited by Sycostang67
