Looking for Staff Members
Overdrive Problems - Vibration / Lots of Black Smoke / High EGT / Sluggish
Hi all,
Started noticing a problem with my truck when it shifts into overdrive. Driving down the road, truck shifts through the gears normal kicks into overdrive and then starts acting differently.
It will cruise fine under light throttle... as soon as I give it throttle, it responds very sluggishly, starts throwing consistent black smoke, the EGT's will jump up, and the truck is vibrating. It will continue to do this until it really gets up and going, or if I let off the throttle.
It really is a pain because the truck drives in overdrive a lot on the 35-50mph roads around here.
This has just started happening and seems to be getting slightly worse.
Any ideas/help as to a diagnosis or where to start looking?
As always thank you in advance for any help.
- FYI...recently put a new turbo in the truck which is considered a slight upgrade I believe with the 59mm inducer.
- Edge Juice with attitude, fass150, 4'' turbo back exhaust, BHAF
  • Replies 9
  • Views 2k
What size tires?
What gear ratio?
Any boost leaks?
Could you get us more specs on the turbo? Typically most report the 3 numbers (54/60/12) 54mm compressor wheel, 60mm turbine wheel, and 12cm2 exhaust housing.
What level and sublevel are you running?
What size injectors are you running?
Just looking again you might look at the TV cable adjustment.
3:55
checked for boost leak didn’t find one
not sure of the rest of the details of the turbo. I will try and find out in the morning.
Not sure what our mean about sub level?
stock injectors
Edge Products work on two settings. Main level which you see on the main screen. The second number is the sublevel it called something different on the Juice. But it in the menu for how aggressive the fueling occurs.
Main Level
  1. 40 HP
  2. 60 HP
  3. 80 HP
  4. 100 HP
  5. 120 HP
Sub level wise is how much boost is required to unlock the fuel.
Was not aware of that. I have pretty much always left it on 3 because it has been the sweet spot.
Sublevels at least for my old Edge Comp.
1 33% stock fuel till 20 PSI of boost
2 50% stock fuel till 15 PSI of boost
3 67% stock fuel till 10 PSI of boost
4 Some extra fuel at low boost
5 Full fuel at zero boost
Does it act like it double shifts ever?  If so I'm kinda with Mike and check the TV cable my brand new trans started acting funny literally last week, do to warranty I took it right to the shop. They found my return spring had broke on the tv cable.
Symptoms it fixed
random unlocking of converter over 60mph
Heavy black smoke from stop, never seen it this bad sorta smoke
Double shift in 1st
Random shutters at 55mph and above
Hope this helps
Edited by WiscoRedkneck
Thanks for the input from all. The truck is at the shop now for Diagnosis...will keep you posted.
Well as an update... I took the truck to a local diesel shop, they test drove it and said they could find nothing out of the ordinary with the truck. In fact, they said it was one of the nicest/best handling 2nd gens they have seen.
I laughed and said, "As stupid as this sounds, I know the truck is acting different, and I am still unsure and want you to find something."
They had the owner drive it next and again said everything checked out normal. I am guessing with the slight upgrade in turbo I am just going to have to get used to the black smoke until the turbo really gets spooled. As far as the slight vibration in overdrive, still scratching my head but again they said nothing out of the ordinary.
These guys could have easily "diagnosed" something wrong that wasn't, but instead took great care of me.
Quote
2002 Ram 2500 110k, Edge Juice With Attitude, 4'' MBRP Exhaust, BHAF, FASS150, 3rd Gen Wheels
Time to ditch the Edge juice and replace it with a Quadzilla. Way better fuel to boost management. You can set all your fuel rates from 0 PSI all the way to 30 PSI (plus) boost. Then you can cut fuel rates BELOW stock value which an Edge Juice can't do. Not even my Edge Comp could do as good as the Quadzilla.
